Connect isvp30 to PHD8
goatlips
Liam @ Prog AV said:
Yes that lead will do it.
What lead would I need and what's the best way to connect it to my pio 434??
Joe Fernand
Outstanding Member
davsdu
Keep in mind that whilst going into the Displays HD15(VGA) socket is possible as YUV you may be better going in as RGBHV with your Analogue sources - so ensure you order a 5BNC to HD15(VGA) cable to go between the VP30 and the Display (you can use this cable for YUV or RGBHV so you can try both settings)..
Also keep in mind if you plan to have any Digital sources that apply HDCP to the Digital Output you will also require an HDMI or DVI (with HDCP) connection between the VP30 and the Display; or employ some form of HDCP stripping plus Digital to Analogue conversion.
Best regards
Joe
⭐Best TVs, Soundbars, Hi-Fi and Home Cinema of 2023
Back
