Connect DVD player through Sky+ box
Discussion in 'Sky Digital TV Forum' started by MCCURLEY, Apr 14, 2005.
  1. MCCURLEY
    MCCURLEY
    Sep 29, 2004
    33
    Is it possible to connect a DVD player to the VCR scart socket on the back of a Sky+ box and watch DVD's through it?
    I am connecting SKY+ (via rgb)-> JS VGA Converter -> PW7 plasma. I would prefer not to use a scart switcher if possible.
    So basically I want to know whether I can connect
    DVD (via scart) -> SKY+ (vcr Scart) -> Sky+ (via rgb)-> JS VGA Converter -> PW7 plasma
  2. gerbilly
    gerbilly
    Mar 20, 2005
    2,193
    Hamilton
    +94
    You sure can mate and you will get a RGB picture as well.
  3. fatherted
    fatherted
    Mar 6, 2005
    87
    Hampshire
    Thanks - I didn't think of that - that helps me
    Leave the sky box turned off (standby) and it does a pass through I guess
  4. gerbilly
    gerbilly
    Mar 20, 2005
    2,193
    Hamilton
    +94
    No you dont even have to put it on standby!
  5. fatherted
    fatherted
    Mar 6, 2005
    87
    Hampshire
    Yes you are correct.
    However I tried it with a cheapy player that plays DVD copies (apparently) and it gives a blank screen. Tried it on component scart and YUV scart - no luck.
    Tried it with an old Toshiba player (won't play DVD-r) and works fine as you suggested.
    Slight red tint at the top of screen - poor scart cable.
    Thanks for the suggestion - got me up and running till I get a panny dvd recorder
