Connect Aego2 to Aego5?
Discussion in 'Home Cinema Speakers' started by stevieo, Jun 28, 2003.
  1. stevieo
    stevieo
    Hi everyone,
    I have an AegoP5 system connected to my tv, dvd, vcr, cable tv in the living room and want to put a couple of speakers in the kitchen so I can listen to music (through the dvd) and radio (through cable tv) in there - if we have a party then we get the same sounds all through. The Aego sounds great so I wanted to use an Aego2 system in there.
    Does anyone know if I can connect an Aego2 to the processor on the Aego5? Can I use the line outputs on the processor directly into the line inputs on the back of the Aego2 subwoofer? And if so, which should I connect, as the processor has a subwoofer output but the Aego2 has only left, right and centre inputs.
    Or am I talking utter rubbish and should just shut up and buy a separate system for the kitchen?
    Thanks very much to anyone who has any advice.
    Cheers,
    Steve
  2. Art Vanderlay
    Art Vanderlay
    Apr 9, 2003
    81
    +3
    I think you would have to connect the front left and front right output connections on the processor to the inputs on the Aego2. This would require a y-splitting cable for each input so that you can connect both your Aego5 and Aego2 inputs.
