Connect a pc soundcard to a Reciever
Discussion in 'Home Cinema Buying & Building' started by dazrr, Apr 24, 2007.
  1. dazrr
    dazrr
    Jan 18, 2005
    142
    Does anybody know the best way to connect a PC to a Reciever?
    I have connected from the sondcard line in to phono using a y cable, my reciever is the sony 1200es. The sound is low with a buzzing noise and does not give 5.1 sound.
    :lease:
  2. lunker
    lunker
    Jun 21, 2005
    239
    +9
    You will need a sound card with optical, coaxial or analogue 5.1 out to get 5.1
    Something like this
    Your low buzzing sound is possibly the volume on your PC is set too high. Try turning the PC volume down and the Amp volume up.
  3. timmorris
    timmorris
    Feb 9, 2006
    432
    +23
    Are you sure that one will do it?
    All sound cards will passthrough 5.1 audio on the optical and coax outputs from a DVD, but only cards with DTS connect or Dolby Digital Live will give you 5.1 from downloaded media or from PC games.
    Tim
