connect 2 sky boxes to projectors
Discussion in 'Home Cinema Buying & Building' started by jimzim, Jan 8, 2012.
  1. jimzim
    jimzim
    Jan 4, 2012
    2
    I have 2 TV,s and 2 projectors in different rooms.
    I have 2 sky boxes with different bouquets on them and a terrestrial aerial
    I would like to view both boxes and terrestrial on all systems but have the option to choose what is showing.
    Is there a tuner I can use for the projectors?
    Any help would be appreciated
  2. HickmottJ
    HickmottJ
    Feb 10, 2008
    132
    Hitchin
    +5
    What cabling do have to the TVs and projectors from the Sky boxes and are the Sky boxes located together? Or can additional cabling be installed?
    A video matrix such as a WyreStorm matrix would be needed to allow you to choose which source I.e. Sky box 1 or Sky box 2 is displayed on any (or all) projector/TVs.
  3. jimzim
    jimzim
    Jan 4, 2012
    2
    Cabling is not an issue as it can be changed to suit currently the output from sky 1 goes to a splitter from output sky 2 to the TV and Sky 1 works on channel 18 and sky 2 on 19.
