Connect 2 amps to 1 pair of speakers!
Discussion in 'AV Receivers & Amplifiers' started by andyh41, May 7, 2005.
  1. andyh41
    andyh41
    Dec 28, 2000
    244
    East Grinstead
    I've got separate hifi amp and AV receiver which I use with the same pair of front speakers. Does anyone know of a switchbox that will allow the connection of both amps to the one set of speakers? I've tried using the amp for the front channels by connecting with the reciever pre outs but I couldn't get rid of an earth loop and it sort of unbalanced the sound anyway. I don't use the hifi half as much as I used to as I can't be bothered to swap over the cables. Any ideas gratefully received.
    Andy.
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,501
    Edinburgh
    +1,237
    I have a rather fancy switch box, my power amp actually has two separate inputs, one of which is connected to my dedicated stereo preamp and the other to the pre-outs from the AV Receiver.
    [​IMG]
  3. rjstott
    rjstott
    Feb 23, 2005
    14
    I recommend you don't attempt this at all. Any cross coupling of amps by accident could be a disaster. Why can't you transfer the input devices from the Hi-Fi amp to the A/V?
  4. andyh41
    andyh41
    Dec 28, 2000
    244
    East Grinstead
    Yes I could just connect the cd player to the receiver but I still want to use the hifi amp for cd listening as it's much better. I know QED used to sell a suitable switching device, but it's no longer produced. If I use a purpose made device I can't see that it would be a risk to the electronics.
  5. shadowlight
    shadowlight
    Jan 23, 2005
    4
  6. geoff66
    geoff66
    You can get what appears to be the same box at Maplin for £9.99. I have one and it has 120ohm resistors connected across the non-live pair. Just to be safe I ensure that both amps are off before switching.
  7. andyh41
    andyh41
    Dec 28, 2000
    244
    East Grinstead
    Thanks guys that seems to be what I need. Geoff66, can you tell if the sound is degraded at all by using the box?
