confusion over Tosh 32ZD26P scan / picture settings
Discussion in 'General TV Discussions Forum' started by nickb23, May 19, 2003.
  1. nickb23
    nickb23
    Jul 21, 2002
    436
    Beckenham, Kent
    +14
    Hi Guys,
    I am really confused over the different scan settings that you have on a Tosh 32ZD26P. On different forums I seem to be getting conflicting information, particaully about the different modes. Can anyone help me get to the bottom of this? My questions are as follows:
    Natural / Active - Are both these @ 100hz or are they 50hz?
    100hz - If above is true, what does this do. If they aren't, I think can work it out.
    Progressive - The TV interprets non prog input and fakes it into looking like progressive. Is this correct
    With the Picture modes, some people are saying that especially for games they use a modified pictue mode 3. If you modify one, this then makes it Picture mode M. Is there anyway you can modify each picture setting seperatley, possibly in a service menu, as I seem to manually change the picture settings for every single device i have, and out of the 3 settings, i find them all totally useless.
    Hopefully this makes sense - but any help would be much appreciated
  2. bibooo
    bibooo
    Aug 15, 2002
    227
    Earth
    +11
    Natural and Active are 100Hz modes; Natural (as the name suggests) gives a less processed and more natural picture (allegedly), Active is supposedly better with sports and other such media.
    Progressive mode (50Hz) gives a pseudo progressive scan image from a non-PS source; It tends to eliminate line structure and IMO gives a more natural picture than any of the 100Hz options.
    Calibrate the picture from Mode 3 with a suitable calibration DVD (Avia, Video Essentials, THX Optimode) and the results should be acceptable for all sources.
    Personally I only ever use Progress Mode, unless I am using my DVD/PS2/Gamecube in progressive scan, in which case the TV defaults to "true" PS.
    Once I had calibrated from Picture Mode 3, I never found the need to adjust the settings for any other sources. It has always produced a natural pin-sharp image with all media.
    Take a look here for more information on set-up and problems associated with this TV.
