Confusion over hq, sp, ep etc..
Discussion in 'Blu-ray & DVD Players & Recorders' started by frothi, Apr 30, 2003.
  1. frothi
    frothi
    I have noticed in many reviews of dvd recorders that the maximum record length using hq is one hour. Does this mean that a three hour disc such as fellowship of the ring was recorded at the equivalent of ep, or are commercial discs recorded using some superior process?
    p.s I've just realised i'd forgotten about dual layer. I suppose then that current machines can only record single layers.
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    Single sided single layer discs hold 4.7Gb of data
    Single sided dual layer discs hold 8.5Gb data
    You can't burn dual layer discs they have to be pressed at a replicating house from glass master.
  3. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,365
    48
    +32
    Have you got a bit more detail on this please,as I wondered why you couldn't do this?
  4. nathan_silly
    nathan_silly
    No burner available can alter the laser head (it would need to re-adjust to write to the other layer).. and there are no Dual Layer DVD-R media out anyway.
  5. bobbles
    bobbles
    you can buy double sided RAM discs to increase the capacity to 9.4GB
  6. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,365
    48
    +32
    I can't see the advantage of these,as you've still got to eject them and turn them over,which is the same as putting another single sided disc in.
    And also,why has my Panny DVD-RAM got a built in fan?
  7. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,365
    48
    +32
    But surely the laser head adjusts anyway to read the 2nd layer of DVD's?
  8. bobbles
    bobbles
    no i can not either really unless the price drops where 2 normal RAMS cost more than a double
    I might be making this up but wasn't there talk of DVD players with lasers above and below negating the need to flip
    I've no idea why you can not write to dual layered discs it would be quite handy
  9. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,365
    48
    +32
    Laser disc players can read both sides without flipping the disc,but they're not that quick,convenient though.
  10. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    Authoring for DVD-9 (Dual layer) is not supported by entry level authoring programs. There are no dual layer burners or likely to be with advent of blu-ray etc.
    You'll need an authoring program that can define the layer break & write the 2 DLT masters required by replicating house who will then create from that a glass master & press the copies.
    It's expensive business & you can't do singles, you are talking about a minimum run of say 1000.
