Confusion and some advice sought
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by antsplan, Oct 4, 2004.
  1. antsplan
    antsplan
    All some much needed help required please.
    Just set up my new Plasma panel (Panasonic Viera 42") yesterday.
    I have a few notable problems, but first ill explain the setup in case this is my problem and I have overlooked something:
    Plasma to SKY + via RGB only scart
    SKY+ to Marantz SR5200 AMP via coax cable
    Plasma to DVD via fully wired scart
    Marantz SR4300? DVD to AMP via optical cable
    BTW the plasma is located in a different room to all other components so if i need to run in any other cables i will have to do so soon as the decrators are due in shortly.
    Problem one - AMP keeps switching off whist watching SKY.
    Problem two - how do i get a video signal from my amp to Plasma in order to access the AMP setup program ( as they are in different rooms id prefer to not have to run any more cables, except if possible to one of the other components locally, i.e. DVD or SKY to AMP Dont know if this is possible)
    Problem three - previosuly as soon as i switched on my CRT TV the amp would automatically kick in, I now have to manually press the power button (think this may be related to problem two ?)
    Problem four - I also ran into my Plasma an S-Video to scart cable (scart at plasma end) in order to connect my PC's video card in the future. I tested this with my DVD player last night (svideo at DVD end and scart at plasma end) and only get a distorted reddish/greenish picture which moves from left to right, audio is perfect but picture is completely unwatchable, what have I done wrong ?
    If anyone could please help out with any of these problems I'd sincerely appreciate it.
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,226
    The Borders
    +2,935
    Hello antsplan
    When you say the Amp switches off - do you mean actually powers down to standby or simply looses connectivity with the Digibox?
    I thought SKY+ only had Optical 5:1 outputs!
    Best regards
    Joe
  3. antsplan
    antsplan
    Joe thx for your reply
    The amp goes to standby, really really stuck with this one, someone please help.
    Thx again
    Ant
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,226
    The Borders
    +2,935
    antsplan
    If you cover up the IR pick up on the AV Receiver does it still switch off when viewing SKY?
    You say the Plasma is in another room - are you using an IR repeater or similar to control the gear in the cupboard? If yes you could be getting lots of stray IR from the Plasma being fired into the AV cupboard!
    Joe
  5. antsplan
    antsplan
    Joe
    I am using a IR to RF convertor, I'll go switch it off, and let you know if the problem stops.
    Thank you
    Ant
  6. antsplan
    antsplan
    Switched off the IR transmitter and receiver and the still keeps switching to standby.
    Anyone any ideas, please help.
    Ant
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,226
    The Borders
    +2,935
    antsplan
    You have a PM.
    Joe
  8. antsplan
    antsplan
    Joe, hallelujah..................
    My problems are solved.
    Sky plus upstairs: I reterminated both ends of coax and voila, it started working again.
    Amp - cutting out: I ran an s-video cable from my amp to TV and manged to gain access to my amps setup prog, messed about with the settings and it now appears to be working a treat. I turned 'night mode' on and set the LFE setting to 00db from off. I do not know what either of these are but its working and im happy with that.
    I sincerely appreciate your offer of help, and hope that perhaps I could return the favour one day.
    Thanks again.
    PS if you know what any of these settings are id appreciate you letting me know.
    Anthony.
