Confusion about Panny Plasma's
Discussion in 'Plasma TVs' started by plaver, Sep 6, 2004.
  1. plaver
    plaver
    Oct 12, 2003
    2,321
    Bannockburn , Victoria, Australia
    +98
    :lease: HELP
    Spec for Panasonic TH42PW6 Widescreen Plasma
    42" (106cm) Plasma Display
    Resolution: 852 x 480 pixels
    Progressive scan
    Pixel pitch: 1.08mm
    Colours: 16.7 million colours
    Luminance: 650 CD/M2
    Viewing angle: 160 degrees horizontal and vertical
    Contrast ratio: 4000:1
    2 x 8 watts
    Scart input
    Remote control
    Input board
    Silver Finish
    Spec for Panasonic TH42PE30 Widescreen Plasma
    106cmV 16:9 Widescreen Panel
    Integrated Digital Terrestrial Tuner & Speakers
    852 X 480 VGA Resolution
    4000:1 Contrast Ratio
    SD/PC Card Slot
    Smart Sound Speaker System
    Multi Window
    Prices, the PE30 is nearly £1000 pounds dearer. This is why I am confused, can someone explain why I should pay nearly a grand more the PE30 or will it cost me this much to turn what is a display screen (PW6) into a TV display screen.
    I already have a Freeview box which will be upgraded to a PVR when Panasonic launch there new PVR later this month (living in hope), I have a conponent feed Pinneer DVD player and a Sony AV amp with Keff speakers. I'm not really sure I want or need a facility to output from my PC. As I've said earlier in thread I need someone to explain the benifit of having PE30 over the PW6 is it worth the money and if so WHY.... I was looking at Pioneer 43inch, turns out to be to rich for my blood, so I am now looking at the Panny
    If you have a comment or thought, all will be read and any information is gratefully received.
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    get the PW6 + free scart board + JS scart plasma to vga box + quintro scart switch box +stand/wall mount
    £1898 + £126 + £61 +£65 = £2200
    or if you want all in 1 box (& higher resolution)
    buy the HD pioneer 43" from John Lewis for £2995
  3. zedzed
    zedzed
    Jul 12, 2004
    817
    Linlithgow (nr. Edinburgh)
    +13
    Where can you get a stand for £65? Is it any good? Website link please :D
    Ta,
    ZedZed
  4. plaver
    plaver
    Oct 12, 2003
    2,321
    +98
    I know about the cost and I wasn't after quotes all be it very expensive and it doesn't answer the queston on in the orginal post.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    well PE30 is TV with lots of features and PW6 is a basic monitor simple really................................
    Personally i would buy a Fujitsu 42VHA with a 2 year warranty as standard. 1 year insight and 2nd RTB... upgrade to 3 years on-site is very reasonable and the PQ IMPO is better than the Panny.....
    http://www.progressive-av.com/flat_screens/fujitsu_p42vha30.htm
  6. SeaMan
    SeaMan
    Is the P42VHA30 really that much better than PW6, given the price difference? I mean, except (quoting the site reference you supplied) some more input options it provides (need to be separately bought for PW6), it's basically Panasonic screen with Fujutsu stuff inside...
    better features, PQ or something else?
