Confusing Xbox HD info
Discussion in 'Xbox Forums' started by Malone, Mar 7, 2005.
  1. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    Humm, I have read various threads regarding Hi Def from a PAL Xbox and find lots of posts that sometimes contradict each other.
    What I would like is to keep my PAL Xbox running fine on XBL and to output Hi Def to my projector via component.
    Exactly what does one need to do this. Soldering is out of the question as I am all fingers and thumbs and would end up buggering up my Xbox, Sooo what are my options.
    Does anyone know the definitive answer :lease:
    Matt
  2. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    You can soft mod it and install the region switch patch. Get the MS High def pack and Jobs done. There are loads of threads on this for the fine detail of the soft mod etc etc etc.
    Personally I just got a switchable chip installed at a computer fair and it works fine on live (I am on there virtually every day) but if you dont want to spend the £40 or just dont want the hardware solution there is the soft mod route which is reasonably easy to do.
  3. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    Thanks for the reply Harrisuk, as I said I have read various posts, heresone for starters. One says do this then another says no dont do that then another etc etc etc. So it can get confusing. I just want the simplest method whilst still using Live. So rather than reading posts which contradict each other I was after the simplest correct method.
    Cheers :thumbsup: Matt
  4. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    I posted a link to a proper walk through for the Soft Mod in A HD thread ages back. Should still be around. My mate used it and it worked no problems.
    Personally I couldnt be arsed and got a switchable chip. It only costs £40, far less hastle.
  5. danvitale
    danvitale
    Nov 18, 2004
    2,340
    63
    By The Sea
    +114
    I had my Xbox on XBL before I soft modded my Xbox to use Hi Def.. It still works on XBL live. All the soft mod does is switch the output mode to NTSC, something the console is designed for...
  6. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    Strictly speaking this is not correct. The soft mod also allows you to run unsigned software (and imports).
  7. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    Would you agree with this.
    Matt
  8. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    Looks along the same lines as the guide I found and posted on here. As I said I have never done it myself but a friend has and it definately works.
    Give it a go sure someone on the forums will have a copy of the game required ;)
  9. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,344
    2
    167
    The Wheldon Road end!
    +8,372
    Again I just use a chip which I can switch on & off. If I want to go on live I just knock it off and i'm away! I run enigma video switcher to change from PAL to NTSC and it works a treat.
    Getting it chipped is pretty cheap (about £40-£50 to be done by someone - my soldering is also pretty poor :D ). There are also solderless chips available which are much easier to fit.
  10. danvitale
    danvitale
    Nov 18, 2004
    2,340
    63
    By The Sea
    +114
    Sorry, what I meant was that the Xbox console is designed to run NTSC or PAL, which ever mode is selected.
