Confused!
Discussion in 'General TV Discussions Forum' started by silent lucidity, Mar 2, 2003.
  1. silent lucidity
    silent lucidity
    First,equipment and hookup details.Running a Tosh SD220e via scart,to scart socket 2 on a Philips 32pw9527.Setup for S-Video as I can't use RGB due to the "black bars phenomenon"(which,as we all know,is in our heads as Philips says the set's fine!).Anyway,the question is this;when I watch a R1 disc the t.v changes the digital options to p+ and prog scan.But I was under the impression the SD220e didn't output a prog scan?The t.v quite happily runs in this option and I have to say it looks pretty good but,what am I actually watching?
    None of this is actually what I call a problem,just need someone to educate my thick head!:blush:
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    It's an internal progressive scan mode using the TVs own deinterlacer.
  3. silent lucidity
    silent lucidity
    I see,how does that compare to prog scan from a DVD player?By the way RCT I have actually now found a use for p+!You may remember some of my posts being very unfavourable about it,but I now have a grundig DVB tuner.Still no good for rapid camera pans,but if viewing say,the music or Sky news channel it does improve the picture.Can't say I'm a converted fan,such as yourself,but you deserve to know I have found some kind of use for it!;)
  4. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Obviously not as good, but an improvement nonetheless.
    Glad you found a "use" for the main feature of your telly! :laugh:
    I'm actually rather suprised at the combination of channels you mentioned... Sky News uses a very high bitrate (best quality digital channel out there) but the music channels are usually fairly low bitrate... Pixel+ tends not to like these!
  5. silent lucidity
    silent lucidity
    It likes the bitrate more than my ears like all that manufactured s**t!Keeping my fingers crossed that the Kerrang channel comes to Freeview!:devil:
