Confused
Discussion in 'Home Cinema Speakers' started by jammods, Feb 11, 2003.
  1. jammods
    jammods
    OK this is the situation I already have some Mission 731's and stands, would these be OK to use in a home cinema setup?
    I dont want to spend a lot of cash....so.....can anyone recommend an amp and centre/rear setup that would complement these... or would it be better to get something like the mission cinema 6 or 72 package.
    As for the amp I dont have a clue, its got to be silver though!
    Thanks in advance
  2. Ravi 123
    Ravi 123
    How much are you looking to spend ? What size room are you using it for ?
