Confused
Discussion in 'Plasma TVs' started by zoltan, Jan 16, 2005.
  1. zoltan
    zoltan
    Jan 15, 2005
    33
    9
    170 MPH with the knee down
    :suicide: I’m a bit confused with the info on AV-SALES which states that the NEC VR5 has a resolution of 1024 x 1024 but on NEXNIX it stated as Resolution 853 x 480 does any one know what’s what or am I being dense and are there any advantages at the moment to go for higher Rez. :suicide: :suicide:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    seems AV sales have not updated the description........its is not 1024x1024 ALIS RES.......but is 852x480.....
  3. zoltan
    zoltan
    Jan 15, 2005
    33
    9
    Thanks Hornydragon but do you think it worth buying a high rez as to normal. I don’t know it make much difference at the moment. :thumbsup:
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    yes if you can afford it and a scaler..........................£3k+ tho.............twice the price..........................
  5. zoltan
    zoltan
    Jan 15, 2005
    33
    9
    Well I think its going to be the VR5 can’t afford much more, Thanks Horny you seem to be a wise hand at this plasma lark, its nearly dun me in. I don’t know what I would have bought if I did not have good advise from all the guy at this forum. Cheers :thumbsup:
  6. BALLISTIX
    BALLISTIX
    Oct 7, 2004
    117
    16
    Depending on what you want to connect up, good cables will cost you a few £££'s too, then wall mount, then,,, then,,, :laugh:
    Andy.
  7. zoltan
    zoltan
    Jan 15, 2005
    33
    9
    There I was just thinking I go down the road a get a plasma But then it starts, one minuet your spending £1500 then £1600 then £1900 and on and on and on and………………………….. :suicide: :laugh:
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    MAY i ask WHY the VR5 over the Panny??? HD TV compatible or another reason?
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    still £1500 on plasma.... but the extras are worthit...Good sound top PQ you can spend £1k but it wont be very good!!!!!
  10. zoltan
    zoltan
    Jan 15, 2005
    33
    9
    Well to be honest there was the issue of HD but in truth I just decided the NEC. You can only read so much about this. I like the Pany 7 but I got a bit confused with what board I need and connections. I run a simple ship I have the Panasonic SC-HT870 & just normal Sky box the Pace and a Panasonic VCR. I was going to call AV for advice but was a bit embarrassed if I did not understand all the Tech jargon. :blush:
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    thats what they are there for (GET paid for) NEC is no easier, can be worse as it has far more connections on the panel most of which you will not use/need.......
  12. zoltan
    zoltan
    Jan 15, 2005
    33
    9
    Your right. Ok what which panel would you go for if you had my budget your advise would be very appreciated as I think you know what your talking about?
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    go see a demo of them both let your eyes decide....not seen an NEC yet so reserving judgement...
  14. creative-av
    creative-av
    Aug 30, 2003
    1,086
    48
    +56
    Zoltan,
    If you can get down to NexNix in Horsham they have the NEC VR5 and the XR3(HD version), a Panny PW6 and Hitatchi 5200 on demo. I think it is one of the only shops that have a Panny and the NEC together so you can get a direct comparison on which one is best.
    Steve
  15. zoltan
    zoltan
    Jan 15, 2005
    33
    9
    :thumbsup: Thanks guys I will give NexNix a call :thumbsup:
