Confused over Progressive Scan
Discussion in 'Plasma TVs Forum' started by scrowe, Jan 9, 2005.
  1. scrowe
    scrowe
    Jan 8, 2005
    1,027
    116
    Brighton
    +556
    I've tried a few web searches and read a few posts, but everything seems contradictory.
    I'm feeding my Pio 505-XDE Plasma with a 3-year old Techtronics-modded Toshiba SD-210E DVD via a decent set of Lektropacks component leads.
    Being currently able to pick up a new Toshiba SD-240E for £50 complete with a multi-region handset hack, is it worth upgrading for the benefit of newer technology and the bonus of progressive scan?
    Their seem to be 2x schools of thought
    a) Progressive scan is of no benefit on Plasmas as they already do their own progressive scan, and it could be the Plasma does better progressive scanning than the DVD player anyway?
    b) Progressive scan is 'intended' for feeding Plasma screens via component leads, and this is the best possible picture, unless you go the HDMI route.
    For £50 it's worth the money to me if there is any picture improvement. So, will it be worth it?
  2. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,836
    71
    birkenhead
    +74
    to my knowledge the plasma will do its own prog scan but if the dvd player does a better job then use the dvd.how you find that out is a bit of trial and error though.
  3. scrowe
    scrowe
    Jan 8, 2005
    1,027
    116
    Brighton
    +556
    Thanks,
    Anyone have any experience of progressive dvd with plasmas?
    Or any other words of wisdom on the subject?
  4. Anthall
    Anthall
    Oct 27, 2004
    220
    Kettering
    +4
    No words of wisdom but my best results are achieved with my
    dvd player and viera connected with component, but with progressive scan
    on the recorder set to 'off'. Ive toggled through turning it on and
    off for for a bit now, and this is the best option for me!
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    If you have a good DVD switch it on, if you have a cheap one or a digital scaler turn it off. Plasmas do their own deinterlacing, which might or might not be better than any given DVD player. I think in your case I'd put the £50 towards a proper HDMI player, don't bother upgrading to another basic player. For god's sake it's a £4000 display, what are you doing with a £50 DVD player!
  6. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Progressive scan doesn't seem to make any difference to my Hitachi 42PD5300, but it makes a big difference to my Benq 6200 projector.
  7. scrowe
    scrowe
    Jan 8, 2005
    1,027
    116
    Brighton
    +556
    It's all I can afford after the £4,000 {:)
    Seriously, up to now, on both my old 46" RP, and new XDE Plasma, the SD-210E (£200 at the time) DVD Player picture has been all around excellent, and £600 is an awful lot to pay just to turn a component-fed display into HDMI, for what may only be a 5-10% perceptible improvement. However £50 for a 1-5% improvement I could do quite easily, especially as the SD-240E gets 5/5 on PQ in all the reviews. I also wanted to keep the HDMI free for Sky's HDTV (hopefully end of this year).
  8. scrowe
    scrowe
    Jan 8, 2005
    1,027
    116
    Brighton
    +556
    After spotting acouple of other threads, I eventually went for the Pioneer DV-575A from Richer Sounds at £110.
    Reviews consider this player worthy of a £500-600 price tag, in terms of PQ & AQ, but the best thing about it is compatibiity, including MP3 & DiVx playback.
    As a bonus, it's nice to have matching components, Plasma, Amp and now DVD.
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    will the de-interlacer in a £50 DVD player be better than the one in your £4k plasma???
    NO
    consider a pio 688 or 868 DVD player to see some real improvements..........
  10. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    The samsung HD-945 (£180) would of given you close performance to the pionner 868 which is £800 via HDMI
  11. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    The output from a DVD player will be non-interlaced, so it doesn't need a de-interlacer. It's really a case of how the digital infomation is read out of memory in the player.
    It's better to start with a non-interlaced signal, than it is to have an interlaced signal and have to de-interlace it. Just one more stage where errors can creep in, and can be eliminated.
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Nick what are you on? DVD is a video storage system and is stored in interlaced format hence needs the deinterlacer...............
  13. stevedster
    stevedster
    Jan 13, 2005
    1,132
    48
    Birkenhead
    +41
    phillfyspoon - just read your sig , u got all that kit and still only 18 :eek: :eek: your mummy and daddy rich or something !!? :laugh: :laugh:
  14. scrowe
    scrowe
    Jan 8, 2005
    1,027
    116
    Brighton
    +556
    Possibly, but I'm anticipating using the HDMI eventually for Sky at the end of the year. Also, I really stretched for the £110, £180 is a bit beyond, and their are a few other plus-points for the Pio, including compatibility and matched components to my current AV stack.
  15. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    It all depends on the source. MPEG can be either interlaced or non-interlaced. See here for more info. MPEG encoding works much better with non-interlaced.
