confused over lcd connections!????
Discussion in 'LCD & LED LCD TVs Forum' started by dingo8yobaby, Jan 1, 2005.
Tags:
  1. dingo8yobaby
    dingo8yobaby
    Jan 29, 2004
    2,050
    83
    a place that haz no reconz:(
    +296
    hi there, i,ve just gotten a kiss 17" lcd tv but it only has composite, s-video and vga inputs and i'm totally baffled as to how i can connect my sky and dvd using the best possible connections- i've heard you can pipe rgb via the vga input but would like to know how much it'd cost and how to do it. sorry if its a simple solution but it would be really helpful. thanks.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,351
    Rainham Essex
    +2,441
    The RGB to Plasma converter from www.js-technology.com is the best way to get an RGB scart output converted to VGA. Don't worry about the plasma part of the name as it will work equaly well on an LCD screen with a VGA input. I have used one of these in the past and the PQ is excellent.
    Mark.
