Confused over CPUs
Discussion in 'Computer Components' started by Oscar21, Aug 16, 2013.
  1. Oscar21
    Oscar21
    Jan 3, 2007
    22
    Can someone please explain the different "H" numbers on intel processors. Due to several cockups I have ended up with a mini ITX case and a celeron G1610 LGA 1155 CPU and I have no idea which mother board is needed.
    I did have a M-ITX motherboard but failed to notice that the socket was 1150, but it did say it was compatible with celeron processors. Can you even get a celeron 1150? I ended up damaging the pins on this MB so its now in the bin. (what a daft idea that pin arrangement is by the way, they are like hairs).
    So what I need is a M-ITX motherboard that will take my CPU, have aHDMI socket with onboard graphics and be a reasonable amount of money, say £60 or so.
  2. cylonwarrior
    cylonwarrior
    Jan 16, 2010
    2,026
    +161
  3. maf1970
    maf1970
    May 2, 2006
    2,118
    Aberdeen
    +305
