confused newbie need all the help possible
Discussion in 'Xbox Forums' started by Fields7, Jan 1, 2007.
  1. Fields7
    Fields7
    Dec 29, 2006
    167
    +6
    Guys this thing about XBMC is confusing me and im no good with all this andcomputers and all that.
    will i need XBMC if i want to play all dvd's and divx dvd's?
    i dont understand how to back up the eeprom and install this
    is there anyone that provides this service as i dont want to mess it up.
    i have ordered a hdtv and would the ms advanced scart be good enough?
    help much appreciated
  2. scumball
    scumball
    Jan 12, 2004
    6,513
    Harrow - London
    +450
    If you are no good with computers and you have an off the shelf XBox but want to use it for DivX playback etc. then I would get it chipped and ask them to install XBMC as the dashboard.
  3. Fields7
    Fields7
    Dec 29, 2006
    167
    +6
    well i dont have knowledge of hardware and things like that
    my xbox still has warranty so dont want to get it chipped but im willing to have it soft modded so that i can change it back and also willing to pay if someone does it (anyone local to leicester?)
    does xbmc need upgrading?
  4. Fields7
    Fields7
    Dec 29, 2006
    167
    +6
    do i have to softmod it to play all video formats on the xbox?
  5. scumball
    scumball
    Jan 12, 2004
    6,513
    Harrow - London
    +450
    Yes, you need to modify it somehow (soft or chip) to load XBMC onto the HDD. Put your name on the list for the forum softmod kit and read the instructions that are available for that particular kit. It's straightforward if you follow it properly....
  6. Tejstar
    Tejstar
    Dec 4, 2002
    22,978
    London
    +1,149
    I only upgraded my XBMC recently after having my old version installed for a year. They recommend regular updates but to be honest if it serves your function then there is no need.
    If you are looking to softmod and do not feel confident in computers then I would sign up for the soft mod kit here - it is very straightforward.
  7. Fields7
    Fields7
    Dec 29, 2006
    167
    +6
    cheers for the reply guys
    ill sign up for that and the i have you guys to help me out if i do get stuck!!! :D
    does the kit come with instructions?
  8. scumball
    scumball
    Jan 12, 2004
    6,513
    Harrow - London
    +450
    As I said before...
  9. Fields7
    Fields7
    Dec 29, 2006
    167
    +6
    anyone willing to do it for me as im not confident enough? (ill pay you for the time)
    i think ill get stuck when it comes to doing it and dont want to end up holding up the kit for everyone else :( :confused:
  10. Fields7
    Fields7
    Dec 29, 2006
    167
    +6
    if anyone is near leicester and would help me do this, ill pay for the time if they want
    cheers
  11. scumball
    scumball
    Jan 12, 2004
    6,513
    Harrow - London
    +450
    huzi, it's easy. Just get everything you need from the following tutorial and follow it step by step. There's nothing to worry about.
    Splinter Cell
    Memory Card
    If you send me a Memory Card I'll copy the saves for you...as will others probably.
  12. Fields7
    Fields7
    Dec 29, 2006
    167
    +6
    ok mate
    ill give it a go
    wherabouts are you mate?
  13. scumball
    scumball
    Jan 12, 2004
    6,513
    Harrow - London
    +450
    Location: Harrow - nowhere near Leicester but a memory card won't cost much to post. I'll throw in a AID 3.10 DVD for XBMC too.
  14. Fields7
    Fields7
    Dec 29, 2006
    167
    +6
    no worries mate
    i really appreciate your help
    :smashin: :cool: :smashin:
