confused even more-please help
Discussion in 'Home Cinema Buying & Building' started by civiccoupevti, Apr 30, 2007.
  1. civiccoupevti
    civiccoupevti
    Jan 18, 2004
    116
    16
    i have had the Sony HTSF1100 on order now for a while and for some reason thought it came with a dvd player!! obviously it doesnt, because it was in the all in one section on the website i just assumed and ordered.
    Now my question is do i cancel and go for a system with a dvd player or do i keep the order and just buy a dvd player?
    If so what dvd player should i go for? if i kepp the system on order, obviously it needs to have a hdmi connection to it, my budget is around £100 on the player it self.
    Or do i go for a all in one system, if so what would you recommend, i have around £350 max to spend, would like it to have hdmi if poss.
    My system is as follows, sharp lc42xd1e,xbox 360
    cheers
    paul
  2. Paulmnj
    Paulmnj
    Apr 24, 2007
    40
    Braintree
    +8
    You could always sell the HTSF1100 to me at a hugely discounted rate? HD DVD players still seem very expensive, you could buy a PS3 which also works well as a blueray HD DVD player via its HDMI connection.
