cineman
Hi. I have a system where I had a Sky HD box and a Sony blu ray player feeding into both a Sony HDTV and an Optoma/Themescene 720P projector. I had a perfectly fine switchbox handling these feeding duties, with no problems and thought that it would still work for my new setup. This is the same PJ, but with a new Philips 'The One' 58pus8555/12 UHD TV and a Panasonic DP-UB820B UHD Blu ray Disc player. Well for some reason that I suppose is obvious, but cannot see it, anytime I want to use the PJ for a film night, I have to change over the hdmi cables, just so I can use this old machine again (recently been fitted with it's third bulb in 12 years, but still a perfect picture!) So I need a new hdmi switchbox that can handle UHD/4K and save me the bother of pulling all the equipment out of the unit, just to change cables over, if such a wee beastie exists? I found that Tesco sells a 'Tesco 4K Hdmi switch 3-way' splitter for £15.00, but this says that it only 'Supports up to 1080p resolution', which is of no use to me and it also said somewhere that it's only v1.4 which seems a little old and outdated. If anyone knows of a more up-to-date switchbox, that can somehow switch between UHD/HDR signals and SDR as necessary, I should be exremely grateful to you. (On another point, I am also confused about why, when cinema projectors can display 'Dolby Vision', why even the most expensive home cinema projectors cannot even get close! Which is why I don't yet have a new projector! But that's just me waffling on and is certainly for another post, so please feel free to ignore me on that bit!)
