Confused after auditioning B&W 600 S3 Series
Discussion in 'Home Cinema Speakers' started by Infamy, Nov 11, 2004.
  1. Infamy
    Infamy
    I went to check out a set of B&W 600 S3 which sounded nice when watching a movie, but when I checked out the fronts (603 S3) in stereo using a CD there was ZERO bass response, I mean my current crappy $50 per speaker setup had twice the kick these did. It almost sounded like there was a high pass filter cutting out the frequencies.
    When I did an A-B between these set and a similar ranged pair of Dali speakers on the same Yamaha amp the difference was immense, not only was the top end richer but they had much more bass response too, it sounded like good speakers are supposed to.
    I was a tad confused about the poor performance of the B&Ws which usually are considered to be fantastic speakers so I went home today to do some research.
    It turns out that every speaker in the Dali ranges are only 4 ohm impedance, where as the B&Ws are 8 ohm. Would this have been the reason the B&Ws were lacking so much in the top & bottom end? I thought 4 ohms took more power to drive than 8 ohm, isn't the result I got backwards? I'm not sure what the amp was rated at but is this just a case of matching the amp & speakers better?
    I'm going to to the only other place in town that has the B&W 600 series to check them out there, but I thought I'd ask to see if anyone can come up with an explanation for my experience.
  2. goodtimes
    goodtimes
    Nov 8, 2004
    769
    28
    +28
    do you have the brass conects in place?
    if not place them back or the speakers need to be biwired to join the 4 posts up.
    just a thought.
  3. Infamy
    Infamy
    Was an in store auditioning, may check when I go back though, thanks
  4. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    The impedance shouldn't have anything to do with bass response - more likely to be a setup problem at the amp end
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,335
    Rainham Essex
    +2,433
    Agree that it is more likely to be a setup problem.
    My thoughts are that perhaps the speakers were connected 'out of phase' which does result in a loss of sound.
    Mark.
  6. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Were the speakers set to small or large?
  7. Infamy
    Infamy
    I got this response on another forum which makes a fair explanation of what I heard
