I'm having my house renovated and I just don't have the budget to stretch to smart light switches. Thus the entire house will be using non-smart light switches. Most of the house will have LED dimmable spotlights. The light switches will be dimmable. There are a few spotlights that will be controllable via 2 ways switches (one side will be a dimmable switch with push on/off and the other side will be a standard on/off switch).
My questions are:
Thoughts/suggestions please?
My questions are:
- Are wifi smart light switches interchangeable with dumb light switches? (i.e. all the wiring for a standard switch is all that is required for the smart switch)?
- If the above is no, what does the smart switch need that the dumb switch doesn't? And is it possible to add that from now while the house is in a state where I can add wiring?
