Hi, After hours of research I am more confused than ever over which subwoofer to buy.
The room which is approx. is 9m (w) x 10m (L) x 5m (H).
I have Kef R series speakers R700 (F), R500 (R), R600 (C), Q800DS (Sur).
The room isn't finished yet but I plan to buy a Yamaha A2030 AV receiver.
No I am confused which sub to buy. The room has had cables at first fix installed so I am not going to have flexibility about where to place the Subs. I have wired some fisual Havana xl sub cables to sit with the front speakers. So my plan is they will be front firing subs and sit inside the main front speakers. I guess this is a challenge when installing cables at first fix (but it is nice and tidy).
So, I am thinking of buying either....
I assume I simply plug the subs into the cable via LFE and let the Yamaha YPAO do its stuff.
However any advice or recommendations welcomed. My budget is ~£1500 for subs but if that's not going to do it then maybe £1000 now and £1000 later in the year.
Thanks Tim
- 2 x Monolith+ Subs
- 2 x SVS PB12's
- 1 or 2 Monitor Audio RXW12
- 1 x Rel 528 (can't afford 2)
- 1 x Rel G1
Thanks Tim
