Confused about Prog Scan (PW6)
Discussion in 'Plasma TVs Forum' started by Lord_Fluff, Apr 5, 2005.
  1. Lord_Fluff
    Lord_Fluff
    Hi all. First post an' all that. Thanks already for the info that this forum has furnished me with. :thumbsup:
    One thing confuses me about inputs to the Panny. If you have a (cheap DVD) PS source should it be fed PS to the screen? I ask as I have read categorically...
    1. YES! You should feed a PS source to a PS screen for best quality
    2. NO! The Panny scaler will do a better job of de-interlacing the RGB signal so dont bother
    Am going to feed by way of JS RGB>SCART box.
    Thoughts??
  2. samjet
    samjet
    Jan 1, 2005
    1,419
    38
    notts
    +5
    i can only give the results as i have found them with my 37" viera and harman kardon dvd22
    i have tried progressive thorough the dvd and then letting the panel do the work - to be honest there was very little difference but at a push i would say that using the player in progressive slightly had the edge
  3. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    i agree with samjet...very hard to tell any difference but I leave the screen to do it.
  4. Lord_Fluff
    Lord_Fluff
    Good news - that'll save me the £85 for a BNC board then :-D
  5. Davidgilmour
    Davidgilmour
    Jan 31, 2004
    781
    Amsterdam
    +15
    If I understand correctly you are gonna use the JS SCART-VGA for the DVD.
    This will give you the PS picture but from what I understand is that the component board will give you a lot better DVD PQ than the SCART-VGA.
    Most people use this option for sources that don´t have component out like Dreamcasts, SNES, old consoles, VCR´s and Sky etc.
  6. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    not sure about that because on the 6 series you can put component into the vga whereas they crippled this feature on the 7 series.
  7. Peabo
    Peabo
    component > RGB Scart
  8. Lord_Fluff
    Lord_Fluff
    Sorry, wasn't altogether clear here.
    I'm yet to even plug up the screen - JS convertor on the way, no other boards as yet, so the question is whether to splurge an additional 85 nicker on the BNC board.....?
