Confused about HD on my Projector
Discussion in 'Projectors, Screens & Video Processors' started by ummy, May 2, 2005.
  1. ummy
    ummy
    Hi all,
    could someone please tell me what hd signal/modes an NEC VT440 will accept for definite?
    thanks
    ummy
  2. stripe
    stripe
    Apr 7, 2004
    1,291
    Scotland
    +123
    From the NEC website it's an 800x600 projector, but it can handle a 1920x1080i and a 1280x720p signal.
  3. ummy
    ummy
    thanks for your quick reply,
    but the thing i wasn't sure about was that the manual says (same manual for the VT440 and VT540) the above hd signals are for the VT540 (i think).
    anyone with a VT440 confirm please?
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    Bear in mind that even if the projector can handle a hidef signal the panel does not have enough res to amke it ;look any better than a normal standard definition image.
