Confused about connection methods!!!!
Discussion in 'Cables & Switches' started by oldskoolskater, Nov 29, 2004.
  1. oldskoolskater
    oldskoolskater
    Hi all
    I want to connect a Pace twin PVR in one room to a 15" LCD tv in another room. The distance under the floor would be about 13m, and I am unsure about which connections to use between the two.
    Both the Pace and the tv have S-video ports, scart, phono audio, so my question is.....
    Which technology would be the best for a long run such as this?
    I have found 15m scart leads but suspect they would be of low quality. Would it be better to go the separate route of s-video/RCA phono audio from the likes of Mark Grant?
    I would not be using the crap speakers on the LCD tv, but going straight to a hifi amp.
    Steve
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I would get some quality cables (for S-Video and audio) and connectors and make the cables myself. If you are handy with a soldering iron it should be no problem and of course it's cheap, too.
