Confused about Component connection
Discussion in 'Cables & Switches' started by albany, Oct 24, 2004.
  1. albany
    albany
    Oct 20, 2003
    30
    The AV receiver that I am considering has Y,Cb,Cr component connectors.
    The monitor and DVD recorder both have Y,Pb, Pr component connectors.
    I have just read various pages on this but am still confused. Some say it will work and yet others say the connection will not work. :blush:
    Anyone know for sure? :lease:
    Many thanks.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    should be fine but model numbers would help mate
  3. albany
    albany
    Oct 20, 2003
    30
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Does DVD direct to Panel work?
  5. albany
    albany
    Oct 20, 2003
    30
    I have not bought it yet so don't know. I am researching before dropping the dough.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    never used the monitor you link to so cant say for definate....if signal from DVD works then siganla via amp will work. amp is just a switch.
  7. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I assume the labelling on the receiver is incorrect.
    YCrCb is supposed to be a digital video signal but often used for the analog form which is called YPrPb. In fact the MPEG-2 encoding on the DVD is based on YCrCb. Both can be summed under the term 'component' (aka YUV).
  8. albany
    albany
    Oct 20, 2003
    30
    You assume right. The manufacturer advised that it is an analogue connection and mislabeled. Though he thinks the bandwidth is sufficient to carry HDTV signals etc... But that is not relevent to me anyway.
    Thank you both.
