Confirming Blu Ray Movie Region code on PS3
Discussion in 'Playstation Forums' started by Ty_UK, May 1, 2007.
  1. Ty_UK
    Ty_UK
    Can anyone tell me how to find what region Code my PS3 is - i just want to confirm the Region Code so that i can start purchasing movies.
    My dilemma is that i bought mine in Hong Kong and although it was bought from a high street chain there i seem to remember the box stating Region 3 on it which incidently would not be correct as HK should be in Region 1 - i have also tried playing a US DVD which i received an incomptible message.
    So in short i was just wondering if there is a way to tell by either checking config settings/information on the software??
    Many thanks
    Ty
  2. charliecossie
    charliecossie
    Aug 10, 2002
    359
    28
    Frankfurt
    +26
    You are confused.
    DVD and BD region coding are not the same.
    Hong Kong is DVD region 3 and BD region A.
  3. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    Also blu-ray region A also applies to North America meaning you can buy US/Canadian blu-ray movies. Some UK ones are also region free although not all. All Fox/Disney/Buena Vista blu-rays are region locked. Some Sony ones are and some are not. Most if not all Warner and Paramount ones are region free. Check the following site out for a list of what is and isn't region free...
    http://bluray.lindsite.dk/
  4. Ty_UK
    Ty_UK
    Thanks but is there a way of confirming on the hardware what the region code is for Bluray - as i dont want to purchase Casino Royale in US and find it not work.
    Its just that i can loosely recall seeing a globe symbol with a 3 in the middle on the box - does that mean DVD region or Blu ray region ???? Help i am confused :)
  5. Tigerblade
    Tigerblade
    Apr 6, 2004
    7,964
    +590
    dvd's regions are designated with numbers, br with letters. So u have a Region 3 dvd player and a Region A br player......
  6. Dave
    Dave
    Jul 3, 2005
    11,496
    163
    +3,401
    Check the faq, the regions are explained in there.
    Dave.
  7. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    There is no way of confirming in the hardware. If you have an HK console then it is definitely Region 3 for DVD and Region A for blu-ray. HK is definitely the same region for blu-ray as the US. You console's box should have both a 3 ( dvd region ) and an A ( blu-ray region ) on it.
    If you look around online you can probably get a UK copy of Casino Royale for the same price or less. The US one is region A only where as the UK one is all regions ( A, B, and C ). Therefore the UK one will work on all PS3's and blu-ray players worldwide. Essentially you can buy either the US or UK version and they will both work on your console.
  8. Ty_UK
    Ty_UK
    Thanks everyone - that explains everything - its just the 3 on the box that threw me. :thumbsup:
    I'm going to get ordering this weekend - does anyone have any suggestions on new great movies to showcase the Blu Ray ?? :)
  9. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    I would suggest checking the following site for reviews ...
    http://www.highdefdigest.com/
  10. KeanosMagicHat
    KeanosMagicHat
    Feb 7, 2005
    4,553
    England, UK.
    +553
