Configuring the Wiimote pointer/Sensor Bar positioning
Discussion in 'Nintendo Wii-U & 3DS' started by Phil_Boggild, Dec 28, 2006.
  1. Phil_Boggild
    Phil_Boggild
    Dec 21, 2005
    528
    +15
    Got my Wii today. Is there any utility to configure or calibrate the Wiimote? It seems ridiculous to me that it wouldn't be an option anywhere...
    You see, when I aim my Wiimote at the screen, the pointer doesn't actually appear where I'm aiming. If I put the sensor bar below the TV, the pointer appears about 4 inches above wherever I'm pointing, so I have to point at the lower section of the TV in order for the pointer to be in the center of the screen. If the sensor bar is above the TV, the pointer appears about 4 inches below wherever I point. It's like the only way I'd be able to get it centered properly would be I the sensor bar were in the middle of the TV screen, which is obviously impossible.
    Heeeeeelp!
  2. longster
    longster
    Nov 19, 2006
    61
    there is a sensor bar positioning option and a sensor bar sensitivity option in the wii options which you access in the main menu
  3. KingOfGondor
    KingOfGondor
    Dec 30, 2004
    559
    28
    +25
    you need to be more than a meter away ideally
    the sensitivity is for changing how far away the remote can be used
    try to make sure the sensor bar isn't too far below or above the TV
  4. Phil_Boggild
    Phil_Boggild
    Dec 21, 2005
    528
    +15
    Yes, I'm aware of both of those, and set them accordingly.
    That's not what I mean. I'm talking about the actual position of the pointer on the screen. There must be a way to calibrate it, surely?
    The sensor bar is currently sitting on top of the TV, and I'm about 1.5 metres away from it.
  5. Coolit
    Coolit
    Mar 23, 2003
    866
    28
    Falkirk
    +54
    Some games have there own calibration tool, Zelda does for one :)
