Quantcast
Configuring/set-up of solwise homeplug access point
bairdyboy1980
I have a solwise homeplug access point i need to configure but i am not sure how to do this. I dont have the original software disks and i have a mac also.
Usually there is a website you log into to config access point, but i am not sure.
The model i have is PL-85PEW_MK2
Hope someone can help!
beerhunter
Yeh i did and found a manual that sorta related to mine. Got into the setup screen... Changed the SSID and saved. Then when i restarted the router it didnt remember the changes lol :-(
I am confused.
The settings on the HomePlug's Wireless Access Point are completely independent of the router.
Similar threads
