Configuring AVR32 speakers
Discussion in 'AV Receivers & Amplifiers' started by leighv, Jun 22, 2015.
Tags:
  1. leighv
    leighv
    Apr 6, 2003
    47
    I am using this for my home cinema setup, and 2 Calliope speakers as my rear speakers for a 5.1 surround system.
    However, I would also like to attach a Sonos Connect to the AVR32, and then use these 'back speakers'. However, I can't seemingly configure the unit to use the back speaker (for the Tape in) only the front speakers.
    Any ideas on how or if I can do this?
    Thanks.
  2. karlknurr
    karlknurr
    Aug 19, 2012
    240
    +23
    I don´t understand what you like to do.
    Could you tell us please:
    -Your AV32R model (Single processor? 7.1 unit?)
    -What did you like do to? (Zone 2? or using the rear speakers for stereo too?)
  3. leighv
    leighv
    Apr 6, 2003
    47
    Hi - it's a 5.1 AV32R. I would just like to use the rear speakers only for stereo - so not the front ones. Thanks.
  4. karlknurr
    karlknurr
    Aug 19, 2012
    240
    +23
    I believe that won´t work. My only idea is to use something like PRO LOGIC etc. + switching the front speakers of.
