Conections?????????
Discussion in 'AV Receivers & Amplifiers' started by bbt, Jan 18, 2008.
  1. bbt
    bbt
    Have seem the thread for the Cambridge 540r v2 which for £150 is a cracking buy but having had a look at it there are no hmdi connections on it or on anything else under £250. The question is do i realy need hmdi or is it just future profing? Now for the thick bit what would i use to connect my sky plus to the av amp?
  2. lfcmonkey
    lfcmonkey
    Mar 26, 2007
    1,219
    Doncaster
    +105
    You need an optical cable to connect sky to your amp....
  3. mjcairney
    mjcairney
    Oct 26, 2003
    7,274
    2
    137
    Airdrie, Scotland
    +1,074
    Also known as Toslink.
    See here for examples.
    Cheers,
    Martin.
