conections for tannoy r3, mx2
Discussion in 'Home Cinema Speakers' started by themoid, Apr 4, 2002.
  1. themoid
    themoid
    Oct 23, 2001
    884
    Staffs
    +30
    just looking for some opinions on the best connections for tannoy r3's, mx2's and mxc speakers. any thoughts gratefully listened to :)
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,465
    United Kingdom
    +1,936
    Banana plugs are probably your best bet, I assume they can accept them. Failing that, bare-wire into the binding post will do.
  3. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    My own set up consists of Revolutions and Rc.They are terminated with plugs at the amp and bare ends at the speakers.
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    U-shaped lugs may also do. Buy from electronic shops, they are way cheaper then your hifi-store ...
