conection for surround sound
Discussion in 'Cables & Switches' started by newjohn, Oct 18, 2005.
  1. newjohn
    newjohn
    i am soon to purchase a new projector to hopefully go with my exsisting surround sound the problem i have is that my JVC-A35 has no component connections and i am told i need this to get a good picture
    i also have a JVC-M10 player recorder and this has a component output
    can i connect the output of the latter to the input of my surround sound
    and still get the 5.1 surround or am i better to get a new player with the outputs i need ? (if so can you reccomend a good cheap system)
    any help/advice please
  2. lee_car
    lee_car
    May 16, 2005
    579
    Oldham
    hi you dont get sound through component connections, you will need to connect phono etc to get sound
    cheers lee
  3. newjohn
    newjohn
    sorry about the bad explanation
    what i am trying to do is play my dvd on the player with component connections as this is better or so im told,
    and as this is not surround sound i wish to link this to my other player that has surround sound but no component and use the second player just as an amplifier so can i and will i get the 5.1 i want
    if so how
    or am i talking nonsence
