Conection boards For PW7
Discussion in 'Plasma TVs Forum' started by Steve_Whelan, Dec 24, 2004.
  1. Steve_Whelan
    Steve_Whelan
    Sep 22, 2004
    118
    +3
    I Have decided to get a PW7, most likley from AV sales, will be getting a scart and component board, do AV Sales fit the boards for you, if not are they dificult to fit as i am not that technical.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    they are easy to fit just unscrew 4 screws push board in a replace 4 screws... very easy not specialist knowledge needed and easier than adding a card to a PC
  3. bazlion
    bazlion
    HD?
    Are they the only boards/connections needed to view Sky+, and a dvd with component(when I get one)At present I have an optical digital connection from Yamaha sound system >> Sky Box and scart >>Tv.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    All you need is scart and component or JS tech box and component
