Conecting poratable player with home stereo
Discussion in 'Headphones, Earphones & Portable Music' started by Przemek, Feb 25, 2005.
  1. Przemek
    Przemek
    hi,
    I'm just about to buy some 3.5mm mini jack to 2xRCA cable to connect my portable music sources (laptop, mp3 player) to my home stereo but... After reading some other post and text abut interconnects cables and cables in general I'm a little bit confuse. So much that I can't decide wich cable to choos. I just don't know if there will be some difference to feel or not. The prices are from 1 euro to 80 euro so it's getting harder.
    There are some cables that I'm thinking of:
    1.IXOS 109
    2.MONSTER iCABLE
    3.Interlink Portable 400 MkII
    4.CHOSEAL
    5.QED Qunex J2P
    6.iCHORD
    well I hope that somebody is also interested in that subject and know more then I do.
  2. K1234
    K1234
    yeah i'm looking to buy the ichord one right this minute, what do you guys think? i have a very very cheap one, and i fancy a little upgrade.
    is the Ichord the one to go for? :rolleyes:
  3. Drd
    Drd
    Jan 22, 2005
    1,904
    Approaching the doghouse at great speed
    +301
    I suppose part of the answer is a question,what quality are the recordings?If they're low quality mp3's then I'd buy a £1 lead off fleabay.If they're high quality then I'd still start with a cheap lead and see what it sounded like as the electronics in portable players are not top quality in my personal experience(mine's a creative zen touch),fine for headphones on the move but not when connected to a decent system
  4. PJTX100
    PJTX100
    Dec 21, 2004
    8,144
    +564
    Wot he said!
    If you are using lossy encoding, a cheap cable will do. You may as well burn a few £20 notes on the BBQ vs buying an expensive cable. :)
  5. delpiero
    delpiero
    I've got a 30gb ipod, and all of the tracks are encoded to mp3 at a pretty low bitrate (between 128kb & 192kb). So I'm guessing you'd recommend a relatively cheap cable, I'm after specific suggestions, please.
    What I'm after is a 3.5mm minijack to 3.5mm minijack
