conecting laptop to tv
Discussion in 'Cables & Switches' started by rphul, Apr 25, 2007.
  1. rphul
    rphul
    May 29, 2003
    63
    london
    hi i am connecting a ibm laptop to a toshiba wlt66 tv. the laptop has both svideo and rgb output. the tv can take rgb or scart as input
    what is the best way to connect the two together, main use will be for playing avi's but may occasionally want to connect as a monitor
    would the following be a good solution?
    http://www.tvcables.co.uk/cgi-bin/tvcables/PCTOTV2.html
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    Looking at http://www.home-entertainment.toshiba.co.uk/consumer/information.nsf/pages/regza1080hd/$File/regza1080hd.pdf?openelement
    The WLT66 has a VGA connector (marked "RGB/PC in").
    Therefore, use a standard VGA 15-pin D-Sub lead.
    You may have to try different resolution settings on the PC for best results.
    Chris Muriel, Manchester
  3. rphul
    rphul
    May 29, 2003
    63
    london
    hi i have used a vga 15 pin lead to connect from laptop to tv. using the tv as a monitor is fine however when i play an avi via mediaplayer or realplayer the area of the screen where the motion should be is blank.
    Have tried the following
    - changed resolution up and down on pc
    - tried a youtube clip, this played fine
    laptop is an ibm t42p
    Any ideas ?
  4. Canti1982
    Canti1982
    May 23, 2006
    1,153
    Haarlem
    +135
    This is not a hardware thing its to do with your graphics display settings. Im not sure how your laptop works, does your laptop screen work at the same time as the tv (monitor)?
    Connecting it via s-video will not help the issue, you need to make sure that the tv is your primary display. If you dont the avi will default to the laptop screen.
    VGA is certainly the best option for you, you might get a bit of horizontal tearing for refresh issues but in general it will provide the best quality connection.
    Hope that helps :)
