Conecting a PS2 to a Quad 405
Discussion in 'Playstation Forums' started by oreoboy13, Jan 7, 2002.
  1. oreoboy13
    oreoboy13
    I am running a composite out of my ps2 with the video signal straight into the TV, the left and right channel and then converted into a DIN conector, which goes into the back of the aforementioned amp. However playback of sound via the PS2 is distant, at a low level and with lots of hiss. This is true irrelevant of which input i connect the din to. I thought it might be the lead, so i used to run my CD player but it worked fine. I am now at a complete loss. Please help.
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    So you are taking the sound from the TV and not the PS2?
    Is normal TV sound coming through okay? If not then there would appear to be a problem with your TV's output.
    You'd better get yourself an RGB PS2 scart that has two phone plugs for stereo sound. Then you can either get a converter to take the phonos and give you a din or cut the cables and make up a din connecter.
  3. oreoboy13
    oreoboy13
    thanks very much problem solved.
