Conecting a dvd player to a RX-V357
Discussion in 'AV Receivers & Amplifiers' started by The Slasher, Aug 25, 2005.
  1. The Slasher
    The Slasher
    Aug 25, 2005
    15
    I am just buying a Yamaha AV Package 57 Home Cinema System the amp is the Rx-V357.
    My dvd player is the panasonic dvd s-27 on the back of the dvd player there is no optical out only coaxial out and on the amp the connectors on the back there is a optical for the dvd player and a coaxial for the cd player can i connect the dvd player to the cd coaxial to achieve dolby digital box or should i buy a converter box? :thumbsup:
