Which glue can be used to glue down the speaker wire on the back of cones??
When playing loud one of the speakers is making a rattleing noise where the wire is hitting the cone,
Any ideas of which glue to use?
its already glued to the cone, but one of them is coming loose, therefore smacking against the back of the cone at high volume.
So its one of wires going in red in the attached pic going to the metal connectors.
Loctite Black Tak 4105 is used by a lot of manufacturers, Black Tak comes in a kit which is the glue and activator. Its a good idea to practise first as you only need a tiny amount of activator.
