TimHiFi
Does anyone know where you can get small square/rectangular cable conduit suitable for speaker cables (lets say silver anniversary for example).
B&Q Offer two types, the self-adhesive stick on the wall type, and the fix-it-yourself type. The smallest they do is something like 8mmx16mm, but stock no connecting bits (angles, corners, joiners, etc).
8mmx16 is still a bit large, and somethjng like 10x10 would be much better.
Once stuck to the wall, the self adhesive ones will not come off without the need for redcoration, and the fit-yourself ones look like they need specical plasterboard screw to fix to a wall (and they seem to be an excesive 32mm long too).
I don't know what to use, or where to go and have a look ?
Can anyone shed some of their own experiences on this ?
Sevenoaks said to Glue Gun the cable to the wall, but I might want to take my cable off the waal sometime :0(
