Concord Absorber XT Isofix Car Seat or ???
Discussion in 'Parents Forum' started by 2010, Jan 8, 2012.
  1. 2010
    2010
    Oct 1, 2005
    942
    W4
    +52
    I've been looking to buy an ISOFIX group 1 car seat for my son but the more research I do the more confused I am :confused:
    Basically all seats seem to have mixed reviews but I've come across the Concord Absorber XT and it looks promising apart from the fact that its new and as a result, has no reviews.
    Does anyone have one or can you recommend the seat you're using?
    I'd be grateful for any input.
    Ps My car is an A3 Sportback
  2. 7ofnine
    7ofnine
    Mar 31, 2009
    3,304
    +438
    We've got a Britax Duo Plus Isofix and very satisfied with it.
  3. alpine101
    alpine101
    Jul 1, 2006
    1,152
    63
    +109
    Recaro Young Sport for us. Not Isofix, but then Isofix is invalidated once they are 18Kg, so instead we looked for a seat with good padding and seat belt fixing arrangements. This one's universal group 1/2/3 so should do him through all his junior years.
  4. 7ofnine
    7ofnine
    Mar 31, 2009
    3,304
    +438
    That weight limit is for rear facing car seats. Once the child is old enough, a forward facing seat can be purchased, with Isofix.
  5. alpine101
    alpine101
    Jul 1, 2006
    1,152
    63
    +109
    Sorry, no it's not. Look up ISOFIX, you'll find it's valid for Group 0 and 1 only. The mounts aren't guaranteed to be strong enough for over 18Kg children.
  6. 7ofnine
    7ofnine
    Mar 31, 2009
    3,304
    +438
    Do you have any specific source for this?
    I was referring to what I read on this website.
    Interested because our 9 year old daughter is using a front facing isofix seat.
    Edit: Also checked the Britax website, and they sell approved Isofix seats for up to 36kg (groups 2, 3)
    http://www.britax.co.uk/safety-centre/360-degree-protection/isofix-faq
  7. alpine101
    alpine101
    Jul 1, 2006
    1,152
    63
    +109
  8. 7ofnine
    7ofnine
    Mar 31, 2009
    3,304
    +438
    That says nothing about a weight restriction.
    Sorry, but can you provide a more specific reference to this weight restriction?
  9. lead
    lead
    Aug 19, 2003
    653
    +62
    Have you considered signing up to Which? online trial for £1? That'll give you access to lots of reviews on child car seats.
    Can you not choose a seat that has been tested and given a good recommendation, rather than a seat that currently has neither?
    I use the Silver Cross Navigator Fix for both of my children. The non-isofix version narrowly missed out on a Which? 'Best Buy' as it wasn't Isofix. So logically the Isofix version must be one?
    I bought it as I liked the styling, the padding (so many of these seats seem to have none) and it reclined by the operation of a dial on the front which didn't require the child to be removed from the seat.
    I wanted isofix as it keeps the seat secure in the car when the child isn't in it and is still easy to remove when required. I didn't want 2 seats flying around the car in the event of a crash.
    In front facing seats, surely the car's seatbelt is doing the job of holding the child (whatever their weight) not the isofix mounts? They're just holding the seat.
