charlie0166
Established Member
- Joined
- Sep 26, 2008
- Messages
- 173
- Reaction score
- 6
- Points
- 44
Hi all - hard question for anyone to answer but I will ask it anyway: I borrowed a friends wheel and pedals the other night and tested it on GT5P. It's the first time I have used one, so I wanted to check if my experience is normal or if there is a problem. When using the wheel the resistance/force feedback seems a bit on or off - when in a straight line it feels 'off' with the wheel quite loose and the control quite imprecise, then when you turn in to a corner the resistance comes on rather abruptly. This makes holding a smooth line in a corner quite difficult, and significantly reduces the benefit that i expected to get. My friend bought it second hand and has never used one before or since so he doesn't know whether it's supposed to be like that or not - and nor do I. So, is this normal? Is it broken? Would it be the same with a G27?
Got GT5 today and want to get the best out of it. if the current experience with a wheel is as good as it gets, I won't buy one. If a G27 will be a step change better I will....
many thanks
many thanks
