Concealing Speaker cable....
Discussion in 'Cables & Switches' started by vee_cee, Dec 31, 2002.
  1. vee_cee
    vee_cee
    Has anyone got any tips/ideas on how to conceal speaker cable between were it comes out from under the carpet and goes up the wall to the speakers
    I will be wall mounting the rear channel Kef Eggs on plasterboard walls
    Other than chasing out a channel, what other ways are neat?
    VC
  2. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    sticky tape to the back of the stands.....
    ad
  3. Tony_Cook
    Tony_Cook
    How about routing a groove out of some dado rail and running that around the room - good for speakers mounted mid-way up wall ?
    Could also run behind coving if you don't have any/it needs replacing - high speakers.
  4. vee_cee
    vee_cee
    Thanks chaps
    I've used wooden coving running up the corner of the room which i then paint in the same colour as the wall
    You can see this on the second page of my home cinema link in my sig
    VC
