Walshy252
Hi all
I'm hoping for some advice or thoughts on how to best conceal cables for a wall mounted TV above a log burning stove. It's probably worth saying from the off that I have read up on the pros and cons and I am intending to resolve the issues with heat with a mantle to deflect heat, and a tilt bracket to reduce viewing angle issues.
I have power sockets either side of the chimney breast and the log burner will be installed dead centre with the mantle directly above. The TV would go directly above that.
So what is the best way to install cable management from the tv down to an A/V system on a stand on the floor next to the chimney breast? Ideally I'd like to make it as future proof as possible but also as little intrusion as possible too in order to save reskimming the entire wall.
Picture attached to show the space. The existing fireplace will be removed for the log burner install.
Many thanks!
Many thanks!
