Comunial Freeview Upgrade Obligation
Discussion in 'Freeview & YouView' started by stuartsjg, Aug 16, 2004.
  1. stuartsjg
    stuartsjg
    Hi, i live in a block of flats with 11 off the 1 aerial. I cant get C5 or freeview as the aerial and dist sys is about 20 years old - there since the flats were built.
    The block is factored by Nationwide[email protected] (Aberdeen) and im wondering if there under any obligation (legal or other) to have the system upgraded as i am paying for (via TV licence) things i cannot recieve.
    I have spoke to them but apparently im the only one who has asked about it. Looking out the back most have sky so prob dont even use the aerial system.
    Any ideas?
    Thanks. :)
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    well if they all have Sat dishes, see if you can have your own aerial, have you tried a FV box? The diat sytem may need an upgrade, or a new antenna but existing cabling might be up to the job, Ask your neighbours, start a petition and contact the dtg to see if they have any advice. Also worth contating your local CAI registered aerial installers, as they may have dealt with the management company before etc
  3. JohnW14
    JohnW14
    Aug 6, 2004
    77
    Wiltshire
    On a legal note, assuming the situation is the same in Scotland as England, to upgrade a functioning aerial system to receive Freeview is an improvement not a repair. Before the freeholder can carry out improvements, he/it must obtain the consent of the flat owners. The only way to force the freeholder (the same as Factor?) to do this would be a mass petition by a majority of the flat owners, as recommended by hornydragon.
