Hi everyone, Running windows 7 64 bit
My computer was a bit sluggish so I clicked to re start. Usual things happened but it would not start up, Vaio logo just hung. After about ten minutes I switched of at the main, I know its risky but there was no other way that I could see. When I re connected it recommended me to check the reason and went to start-up check. This went on for about half an hour after which it said it could automatically repair the problem and again suggested I let it try restore to an earlier time, which I did. This went on for over an hour and would not let me cancel so I switched off again with the computer button, waited and then switched it on, low and behold it started up and it is obviously running now otherwise I wouldn't be on here. After all that my question is, should I be worried, can I do anything to avoid this happening. I did run Malwarebytes that found nothing and I never paid any ransom.
Regards
Regards
