computer speakers - Logitech Z-5500- any good?
Discussion in 'Home Cinema Speakers' started by twebbas, Aug 31, 2005.
  1. twebbas
    twebbas
    Aug 30, 2005
    10
    Hassleholm
    Didnt know where to put this thread. Any moderator, feel free to move this one to the right place!! :)
    I was just wondering if anyone has tried Logitech Z-5500 5.1 THX? Can you recommend them? Im about to buy them and connect them to:
    1. my computer
    2.my normal dvd-player
    Any help/info/suggestions would be great.
    Thnx
  2. Andrathion
    Andrathion
    Aug 30, 2005
    123
    +3
    Well, I have the Logitech Z-680 set (which preceded the Z-5500) and I'm quite happy with it. They were certainly among the best 5.1 PC speakers around at the time and I would suspect the Z-5500 would be even better.
    Two small caveats with regard to the Z-680, though (which might also apply to the Z-5500). The speakers produce a slight hiss which some people might find annoying. And the bass is pretty hefty - depending on where you live, you may wish to take your neighbours into consideration!
  3. Spangle2k5
    Spangle2k5
    Aug 10, 2005
    354
    28
    Kettering
    +29
    I have the Z560's hooked up to my PC. These came before the Z5500's but offer very impressive sound indeed (certainly for a PC).
    A hiss is clearly audible at any semblence of volume, but I believe in my case that this may just be the PC sound card (SoundBlaster Live 5.1).
    Will agree with previous comment about bass, I have mine turned down before the signal is output from the PC otherwise it is just too much.
    The only point which I would make is that these speakers I am guessing may only have inputs for a PC, so you will possibly need to invest in some inexpensive adapter plugs to enable you to connect up your AV equipment.
