computer says no
Discussion in 'Desktop & Laptop Computers Forum' started by corsair, Feb 2, 2009.
  1. corsair
    corsair
    Jan 10, 2005
    49
    help needed.
    shut down my acer aspire t180 Friday night o.k.
    switched on Saturday morning and wont start!first screen comes up before post screen saying acer and del:enter setup f12 :boot menu
    pressed f12 and f8 repeatedly and nothing happpens.
    put acer rescue disc in dvd drive spins up but still stuck at first screen .
    could the problem be , failed motherboard?
    failed harddrive ?
    failed processor
    or none of the above?
    running xp by the way:mad:
    have swapped memory and it doesnt make any difference.
    how do I get past this first screen?
    any ideas before I "BOOT" it out the window.
    thanks in advance
  2. tonytiger73
    tonytiger73
    Jan 25, 2009
    28
    3
    +3
    I'd have thought most likely causes were motherboard or processor, or possibly the bios? Does it beep at all?
    Fairly certain it won't be the hard drive. I suppose it could even be power related.
  3. corsair
    corsair
    Jan 10, 2005
    49
    Hi Tony thanks for the reply forgot to say powersupply and processor fans runing,no beeps and indicator lights come on momentarily on key board .
    daft question , is bios built into motherboard because I cant seem to acess it as I cant get any further than this first screen:confused:
    cheers
  4. Abbadonuk
    Abbadonuk
    Jan 25, 2009
    41
    Birmingham
    +5
    The BIOS lives on a chip which is part of the motherboard, and yes it is probably a failure of MB, CPU or RAM.
    If it won't boot at all past post "not even from a restore CD/DVD" then the BIOS is probably OK but one of these 3 things has died.
  5. corsair
    corsair
    Jan 10, 2005
    49
    Hi, computer now says YES
    fitted a new motherboard and every thing working fine. hope this helps anyone else as it seems a common problem through googling.
  6. JonRushton
    JonRushton
    Jul 27, 2007
    85
    +5
    A little too late now, but did you try to reset the bios by shorting the jumps or removing the bios battery?
    I've had that same problem before on a machine at work. Shoddy custom bioses that compaq and other such companies use have hissy fits every now and then.
    Jon
  7. corsair
    corsair
    Jan 10, 2005
    49
    Hi M8,
    Yes tried both of those and still no joy , so made a lucky guess with motherboard .
    thanks for your help though
  8. JonRushton
    JonRushton
    Jul 27, 2007
    85
    +5
    Ahh, no worries mate. glad you got it sorted.
