Quantcast
Computer monitor & Sky box black screen
adamCCC
Hello
I'm trying to connect my computer monitor to my sky box but all im getting is a black screen. Green light on monitor is constantly on so its receiving some sort of signal.
Monitor is a 24" BenQ G2420HDBL. Using a dvi to hdmi cable.
Any help would be much appreciated.
Adam
Trollslayer
Computer monitors usually don't support broadcast video frame rates (25/30 frames per second).
They normally support 50/60/75 frames per second so that wouldn't work.
adamCCC
Thanks for the reply.
Lots of people online reporting no problems connecting their computer monitors to sky :( guess mine isnt compatible
Trollslayer
It varies from one model to another.
Unfortunately the user manual for that monitor is hard to find.
adamCCC
new development.. ive worked out that if i have all the leads connected up, then unplug and plug in the sky box, I get the "SKY +" welcome message on the monitor, but soon changed to a blank screen.
It as though it only receives an action connection at the point it is turned on.
After the sky box is turned on, and the 'Sky +' message disappears, by default the box goes into standby mode. It is at this point the monitor seems to lose connection. When I then turn the sky box on via the remote, nothing happens.
Trollslayer
Most set top boxes including Sky use Linux so that will be Linux going through the normal boot process and looking for a monitor including normal monitor frame rates.
In standby just about everything is still running so boot up only happens when power is applied.
Trollslayer
It's simple. You need a display that supports 25Hz frame rate to watch content.
adamCCC
right, it works on the sky overlay i.e. if tv guide is up, or the settings menu etc etc.
as soon as i put a channel or a recording on, it cuts out back to a black screen
Trollslayer
Not if you want to use a Sky box or just about any set top box.
Trollslayer
50hz interlaced which is 25 full frames per second.
Subject closed, you need a TV plus the display needs to support HDCP.
Get a TV.
adamCCC
Just a little update.. I got it working.
Had to change the resolution settings in sky settings to 720p, and it now works.
So subject wasn't closed, you just didn't know the answer!
davemurgatroyd2
Have you tried changing the video output of the Sky box? In "Services" "Settings" "Picture" -- HD resolution has 4 options - 576, 720p, 1080i and automatic. I suggest trying 576 first.
Similar threads
Trending threads
